1 members (klhansen), 98 guests, and 0 robots.
Topics128,126
Posts1,056,356
Members48,441
#760410 07/07/2011 4:10 AM
'51 216
I have the original fan. A new water pump was donated. The heads of the rivets that hold the blades together hold the fan maybe 1/8" away from the face of the pump pulley. I can't remember if this gap was present with the original pump. I turned in the original pump for the core. I thought I had compared the two to make sure they were the same.
So, the question is, should there be a gap, or should the diameter of the pump fit inside the fan rivets?
Dave
www.fallenherosdreamride.org
all give some
MY SON GAVE ALL
The fallen hero's dream ride is a 1951 Chevrolet 3100 with original 216
In memory of LCpl Phillip Vinnedge USMC KIA 10/13/2010 Afghanistan
Original pulleys have a recess to clear each rivet.
My Blog
I had this same problem. My original also had a stamped pulley that was held on by the bolts and my replacement had a one piece cast pulley. I had to grind little divets where the fan rivets touch. You don't want the fan just resting on the rivets but on the flat face.
1951 1 Ton Completed
Thanks. I didn't think it should be resting on the rivets. Didn't think about just ginding little divets. The rivets hit right on the edge, so it should be pretty simple.
Dave
all give some
MY SON GAVE ALL
