2 members (klhansen, 2-Ton),
85
Mod | | | Forums66 Topics128,037 Posts1,055,465 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 46 New Guy | | New Guy Joined: Apr 2006 Posts: 46 | My '53 GMC has been running well for a year or two, but recently when I drive it, I hear some awful sounds coming from the engine or tranny. It starts after I've driven it for a while and the engine has warmed up. It sounds like metal on metal so I am wondering about fluids. The oil is full, don't know about the tranny fluid. Also wondering if the sound is coming from the water pump, fan. or some other moving part that might need lubricating. Any ideas? Thanks, Craig in Minneapolis
1953 GMC half-ton
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Get yourself a mechanics stethoscope to help you pin point the noise. | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Probably should check the transmission fluid as well... | | | | | Joined: Aug 2004 Posts: 1,417 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,417 | Need some more information here. Does the noise happen all the time once warm? Driving, stopping, speeding up, slowing down?
Where is the general area the noise is coming from?
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Apr 2006 Posts: 46 New Guy | | New Guy Joined: Apr 2006 Posts: 46 | Hello, I started it up today and as soon as I began to push the clutch pedal in, I heard the the high pitched squeal. I let off, it stopped. I pushed in, it started. ??
Craig
1953 GMC half-ton
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I would not think a water pump would make noise depending on whether you push n a clutch or not. sounds like maybe a throw out bearing or something to do with the clutch area.. click here for suggestions for clutch problems
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2010 Posts: 86 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 86 | My vote would be on the throw out bearing. If the squeel changes when the TOB is accuated it gotta be the TOB. pull the cover on the bottom and look for a grease zert. It sounds like it's to late for grease though. lug | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | It is possible that the act of disengaging the clutch could be pushing the crank shaft forward.
Last edited by bigbadswingdaddy; 07/08/2011 4:16 AM. Reason: wtf... changed thought mid sentence
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | As mentioned my number 1 would be the through out bearing. I would also suspect the front bearing in the transmission, pilot bushing, broken finger on the pressure plate. Don | | | | | Joined: Apr 2006 Posts: 46 New Guy | | New Guy Joined: Apr 2006 Posts: 46 | Thanks for the info and ideas. I want to check out the throw out bearing. Are there any pictures or diagrams online that would help me out? Craig
1953 GMC half-ton
