0 members (), 170 guests, and 7 robots.
Topics128,078
Posts1,056,035
Members48,433
#759095 07/01/2011 10:20 PM
Members:
I just put my parking brake back together and it won't work. I took it off again, stretch the spring alittle, filed the edge of the cinch bar..put it all back together and it won't bite. I made sure there was nothing around the spring. I do had a pad and carpet...will that effect the cinch tightness? The curved bar goes thru the cinch rod, thru spring,washer,leather spacer the thru the rubber bumper warped washer and cotter pinned.Doesn't look like rocket science but it has me stumped.
1954 Chevy 3100 5-Window
More pix on Photobucket
"True victory is victory over one's self."
Krav Maga isn't pretty ... but it works just fine.
Jimmi V.
Sounds like you have an older truck, but with my 55.2 I had to tighten the brake pads. If they are very loose the the e-brake won't work. Do you find the pull on the lever quite long? Mine is very short now that it works.
Jo, I have just completed a complete brake system rebuild. The parking brake is tight.
Thanks for the input.
Jimmi V.
My pedal kept popping off and I discovered that if I pushed the release handle in at the same time as I was depressing the brake it would stay in place.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
You mean push release towards the firewall,to lift the lower part of the biting part higher off the floor...I'm on duty for 2 days..buy I will try when I get home...I can't stand when stuff doesn't work right for no apparent reason.
Jimmi V.
