| | | Forums66 Topics128,077 Posts1,056,012 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Members: I just put my parking brake back together and it won't work. I took it off again, stretch the spring alittle, filed the edge of the cinch bar..put it all back together and it won't bite. I made sure there was nothing around the spring. I do had a pad and carpet...will that effect the cinch tightness? The curved bar goes thru the cinch rod, thru spring,washer,leather spacer the thru the rubber bumper warped washer and cotter pinned.Doesn't look like rocket science but it has me stumped. Thanks | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Sounds like you have an older truck, but with my 55.2 I had to tighten the brake pads. If they are very loose the the e-brake won't work. Do you find the pull on the lever quite long? Mine is very short now that it works. | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Jo, I have just completed a complete brake system rebuild. The parking brake is tight. Thanks for the input. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | My pedal kept popping off and I discovered that if I pushed the release handle in at the same time as I was depressing the brake it would stay in place. | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | You mean push release towards the firewall,to lift the lower part of the biting part higher off the floor...I'm on duty for 2 days..buy I will try when I get home...I can't stand when stuff doesn't work right for no apparent reason. Thanks | | |
