1 members (Materman),
107
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Members, going to change out my radiator...checking the internet and my catalogs...There's alot out there... and they run the gamit on pricing, 2 or 3 or 4 core etc. Any opinions bout which one to buy and why. There are alot to choose from and I don't want to automatically go to the cheapest if that will be bad in the long run. I just want one that will be reliable and keep the truck running cool. Thanks in advance for the help | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | What motor and transmission do you have? | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Hot Rod, 1954, 235, 4 speed. Hope this helps. Thanks | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | If you are not a "pure stock" person, then the aluminum 3 or 4 core would be the way to go (in my opinion). Bolt an electric fan in front of it and never have to worry about water tempature............
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I just replaced the radiator in my '50 Chevrolet and put a US Radiator in it. It was a direct replacement, 3 row, copper/brass. I know its been talked about lots in other posts also. I had mine out friday night and it was 97 and humid, sitting in traffic the temp stayed just a bit over 180. I'm more than pleased. Don | | | | | Joined: Jul 2011 Posts: 10 New Guy | | New Guy Joined: Jul 2011 Posts: 10 | if its going to be a daily driver my choice would be aluminum with the electric fan like johntsmith said. good luck | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | If you go with and upgraded core like a four make sure you have the clearance between it and the fan. There was a thread on here a few months back where the thicker cores caused clearance problems. I purchased mine from ClassicParts (Standard Capacity) they mention in their catalog the issue with clearance for the Desert Cooler style they sell as well. Utah summers see 90-100+ deg days and my truck (rebuilt 54' 235) would vent a little pool of coolant after a long drive but I added a reproduction condensor tank which eliminated that. There are lots of choices out there, good luck.
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I installed the same one that Brad did in my 1951 suburban(1956 235).It has been in it almost 2 years,no problems to mention.The box it came in said counter parts. Radiator I used made in the USA and has the transmission cooler built into it.It comes with threaded plugs to plug the holes,when using a manual transmission. Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Jimmie V I would go with a stock design radiator, not aluminum.
If you introduce any aluminum components in a cooling system you should change the anti-freeze at 15,000 mile intervals. The antifreeze can become acidic and can cause deteriorization of alumnium components.
This same acidic condition isn't nearly as caustic to steel components.
Do a Google search on "acidic antifreeze aluminum".
Why use aluminum and introduce another variable?
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I agree; it's a small thing, but enough small things and you have a large bag of things.
~Jim
| | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Thanks guys,I'm probally going to go with classic parts...they give a discount? and how do you go about getting it. Thanks | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | classic parts...they give a discount? and how do you go about getting it. Thanks If you order on line there will be a box that says "promotional code" when you check out. (Editor's note: When you donate to Stovebolt.com you are eligible for the discount. Please don't post the code for anyone with Google to find.)
| | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Man, i wish I would have paid more attention to that...before I started last winter with the rebuild......Just lost alot of money being un-informed... | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | (Editor's note: When you donate to Stovebolt.com you are eligible for the discount. Please don't post the code for anyone with Google to find.) I am a contributing member and encourage all who benefit fronm this site to do so also. When I did make a contribution to the site I was given a discount code for Jim Carter. I was also advised at the same time that there was no code for American Classic. And noting was mentioned about a code for Classic Parts. Peggy M gave me the J.C. Code via P.M. Use the paypal link below to donate . http://www.stovebolt.com/office/thanks.html | | |
