4 members (Hotrod Lincoln, 55shaker, rfs56trk, Wally / Montana), 99 guests, and 3 robots.
Topics128,065
Posts1,055,868
Members48,428
#759803 07/04/2011 11:50 PM
Members, going to change out my radiator...checking the internet and my catalogs...There's alot out there...
and they run the gamit on pricing, 2 or 3 or 4 core etc.
Any opinions bout which one to buy and why. There are alot to choose from and I don't want to automatically go to the cheapest if that will be bad in the long run. I just want one that will be reliable and keep the truck running cool. Thanks in advance for the help
1954 Chevy 3100 5-Window
More pix on Photobucket
"True victory is victory over one's self."
Krav Maga isn't pretty ... but it works just fine.
Jimmi V.
Jimmi_V #759810 07/05/2011 12:04 AM
What motor and transmission do you have?
Hot Rod, 1954, 235, 4 speed. Hope this helps.
Jimmi V.
Jimmi_V #759912 07/05/2011 1:04 PM
If you are not a "pure stock" person, then the aluminum 3 or 4 core would be the way to go (in my opinion). Bolt an electric fan in front of it and never have to worry about water tempature............
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
~Jim
I just replaced the radiator in my '50 Chevrolet and put a US Radiator in it. It was a direct replacement, 3 row, copper/brass. I know its been talked about lots in other posts also. I had mine out friday night and it was 97 and humid, sitting in traffic the temp stayed just a bit over 180. I'm more than pleased. Don
if its going to be a daily driver my choice would be aluminum with the electric fan like johntsmith said. good luck
If you go with and upgraded core like a four make sure you have the clearance between it and the fan. There was a thread on here a few months back where the thicker cores caused clearance problems. I purchased mine from ClassicParts (Standard Capacity) they mention in their catalog the issue with clearance for the Desert Cooler style they sell as well. Utah summers see 90-100+ deg days and my truck (rebuilt 54' 235) would vent a little pool of coolant after a long drive but I added a reproduction condensor tank which eliminated that. There are lots of choices out there, good luck.
I installed the same one that Brad did in my 1951 suburban(1956 235).It has been in it almost 2 years,no problems to mention.The box it came in said counter parts. Radiator I used made in the USA and has the transmission cooler built into it.It comes with threaded plugs to plug the holes,when using a manual transmission.
Tim
1951 3100 Chevrolet
Jimmi_V #760112 07/06/2011 1:42 AM
Jimmie V I would go with a stock design radiator, not aluminum.
If you introduce any aluminum components in a cooling system you should change the anti-freeze at 15,000 mile intervals. The antifreeze can become acidic and can cause deteriorization of alumnium components.
This same acidic condition isn't nearly as caustic to steel components.
Do a Google search on "acidic antifreeze aluminum".
Why use aluminum and introduce another variable?
I agree; it's a small thing, but enough small things and you have a large bag of things.
~Jim
Thanks guys,I'm probally going to go with classic parts...they give a discount? and how do you go about getting it.
Jimmi V.
Jimmi_V #760196 07/06/2011 1:15 PM
If you order on line there will be a box that says "promotional code" when you check out.
(Editor's note: When you donate to Stovebolt.com you are eligible for the discount. Please don't post the code for anyone with Google to find.)
DADS50 #760231 07/06/2011 3:23 PM
Man, i wish I would have paid more attention to that...before I started last winter with the rebuild......Just lost alot of money being un-informed...
Jimmi V.
DADS50 #760265 07/06/2011 7:36 PM
I am a contributing member and encourage all who benefit fronm this site to do so also.
When I did make a contribution to the site I was given a discount code for Jim Carter. I was also advised at the same time that there was no code for American Classic.
And noting was mentioned about a code for Classic Parts.
Peggy M gave me the J.C. Code via P.M.
Use the paypal link below to donate .
http://www.stovebolt.com/office/thanks.html
