8 members (Otto Skorzeny, Wally / Montana, Jeff Ogden, Peggy M, amtrakjoe, moparguy, mvigo, walter74),
83
Mod | | | Forums66 Topics128,130 Posts1,056,702 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 55 | I assume the steering gear in a two ton is bigger than in a half ton because no matter where I put the engine the darn steering gear is in the way. I am currently thinking of using a steering gear from a ford f5 or f6. any thoughts? I know somewhere someone has done this before. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Same issue with a 1/2 ton... people either shim the box out from the frame and or some magical exhaust manifold.. or a different box alltogether.
If you're going to use a different box i'd look for something more modern than an f6.
Grigg | | | | | Joined: Jul 2004 Posts: 2,989 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,989 | On my 1 1/2 ton, the box was moved to the left. The tire will rub it on a hard left turn. I just try not to make any of those!!  | | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | People are talking over on the HAMB of mounting the engine a few inches towards the passenger side, claims are that it's regularly done with early and late model engine placement, and most of the time your 200# butt is on the driver's side so that a more even weight distribution is realized. Food for thought...
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
