2 members (Hotrod Lincoln, Shade Baby), 66 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
I assume the steering gear in a two ton is bigger than in a half ton because no matter where I put the engine the darn steering gear is in the way. I am currently thinking of using a steering gear from a ford f5 or f6. any thoughts? I know somewhere someone has done this before.
Same issue with a 1/2 ton... people either shim the box out from the frame and or some magical exhaust manifold.. or a different box alltogether.
If you're going to use a different box i'd look for something more modern than an f6.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
On my 1 1/2 ton, the box was moved to the left. The tire will rub it on a hard left turn. I just try not to make any of those!! grin
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
ODSS President
ODSS President
People are talking over on the HAMB of mounting the engine a few inches towards the passenger side, claims are that it's regularly done with early and late model engine placement, and most of the time your 200# butt is on the driver's side so that a more even weight distribution is realized. Food for thought...
~ Cosmo
1949 Chevy Half Ton
