1 members (baldeagle), 68 guests, and 1 robot.
Topics128,037
Posts1,055,467
Members48,424
#759032 07/01/2011 4:59 PM
My '53 GMC has been running well for a year or two, but recently when I drive it, I hear some awful sounds coming from the engine or tranny. It starts after I've driven it for a while and the engine has warmed up. It sounds like metal on metal so I am wondering about fluids. The oil is full, don't know about the tranny fluid. Also wondering if the sound is coming from the water pump, fan. or some other moving part that might need lubricating. Any ideas?
Craig in Minneapolis
1953 GMC half-ton
Get yourself a mechanics stethoscope to help you pin point the noise.
Probably should check the transmission fluid as well...
ODSS Lawman
ODSS Lawman
Need some more information here. Does the noise happen all the time once warm? Driving, stopping, speeding up, slowing down?
Where is the general area the noise is coming from?
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Hello,
I started it up today and as soon as I began to push the clutch pedal in, I heard the the high pitched squeal. I let off, it stopped. I pushed in, it started. ??
Craig
1953 GMC half-ton
I would not think a water pump would make noise depending
on whether you push n a clutch or not. sounds like
maybe a throw out bearing or something to do with the clutch area..
click here for suggestions for clutch problems
Redryder pix
My Hotrod
My vote would be on the throw out bearing. If the squeel changes when the TOB is accuated it gotta be the TOB. pull the cover on the bottom and look for a grease zert. It sounds like it's to late for grease though. lug
It is possible that the act of disengaging the clutch could be pushing the crank shaft forward.
Last edited by bigbadswingdaddy; 07/08/2011 4:16 AM. Reason: wtf... changed thought mid sentence
As mentioned my number 1 would be the through out bearing. I would also suspect the front bearing in the transmission, pilot bushing, broken finger on the pressure plate. Don
Thanks for the info and ideas. I want to check out the throw out bearing. Are there any pictures or diagrams online that would help me out?
Craig
1953 GMC half-ton
