| | | Forums66 Topics128,131 Posts1,056,723 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#7590 03/18/2002 12:56 AM | Joined: May 2001 Posts: 71 Shop Shark | | Shop Shark Joined: May 2001 Posts: 71 | I'm still looking for leaf springs for my '53 1/2 ton, I want it to ride at normal height. I'd like to see what other vehicles people got theirs out of and to see how it looks. But if I just go to the wreckers, how many leafs should I get? I'll get it out of a 1/2 ton. Should I measure the original from bottom center to top and look for one of the same, or will that not matter since it'll be a wider spring and different # of leaves?
'53 Chevy truck 1/2 ton
| | | | | Joined: Jul 2001 Posts: 20 Member | | Member Joined: Jul 2001 Posts: 20 | The 53 leaf spring will most likely be narrower (width) than springs you may find from later model trucks. Length is another issue.
I would shop through some of our vendors for the correct springs. They don't cost that much and will be just right for your truck.
1954 Chevy 3100 454, T-400, GM 14-Bolt Disc brake Monte Carlo Front Clip
