7 members (Ribside, BarryP, Ol' Red, Donf, Rusted Nut, TomGMC, 3B), 95 guests, and 2 robots.
Topics128,134
Posts1,056,738
Members48,454
I'm still looking for leaf springs for my '53 1/2 ton, I want it to ride at normal height. I'd like to see what other vehicles people got theirs out of and to see how it looks. But if I just go to the wreckers, how many leafs should I get? I'll get it out of a 1/2 ton. Should I measure the original from bottom center to top and look for one of the same, or will that not matter since it'll be a wider spring and different # of leaves?
'53 Chevy truck 1/2 ton
The 53 leaf spring will most likely be narrower (width) than springs you may find from later model trucks. Length is another issue.
I would shop through some of our vendors for the correct springs. They don't cost that much and will be just right for your truck.
1954 Chevy 3100
454, T-400, GM 14-Bolt Disc brake
Monte Carlo Front Clip
