| | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#75860 04/02/2007 5:22 PM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Hey Guy's, I can't seem to find the torques for the crankshaft caps, main rear and rods for my 60, 235. I did a search but no luck. anyone have those? Head bolt torque would be nice too. Thx. Glenn, | | |
#75861 04/02/2007 8:18 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Head bolts are 90-95 ft lbs. Main bearings are 100-110 but I cannot find the rod bearing values only the end clearance is mentioned at .003-.009 in my 57' shop manual. 1960 235's should be the same. Plastigage should be used for the mains at .001-.003. | | |
#75862 04/02/2007 9:40 PM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | From the shop manual; Connecting rod bearings, Torque oiled threads 35 - 45 ft/lb. | | |
#75863 04/03/2007 12:38 PM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | | | |
