8 members (Gdads51, Brian Moore, TUTS 59, Hotrod Lincoln, Bill Hanlon, Ponchogl, sron48, 1 invisible),
74
Mod | | | Forums66 Topics128,045 Posts1,055,528 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Hello, I have a 1972 Chevy 4x4 with original top loader 4-speed(granny gear) that is stuck in neutral. Went to shift from 2nd to 3rd last week....went into neutral and that was it!!
Any suggestions?
Thanks, Steve in I-DA-HO | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Sounds like the shifter broke off. If you push down on the collar and turn it you can lift the shifter out and take a look. Don | | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | I will try it Don...not a tranny guy by no means. Thanks and will post what I find. Thanks | | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | How do I push it down Don? Can't be this difficult but I am trying not to break anything else ya know.
Thanks, Steve | | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Oh...what am I looking for once I get it off? | | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Got the shifter out and it is not broke. I can see where it sets in the little slots. Any other suggestions? Is it possible that the pressure plate collapsed and it is stuck in neutral? Thanks, Steve | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Take a big screwdriver & put it in the hole & down into the opening in the rails. The slots. If it is in neutral all the slots should be lined up. Try to move one of the rails with the screw driver. Each on should go forward & back one at a time. 2 rails cannot be moved forward or back when another is. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
