1 members (baldeagle), 61 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#758495 06/29/2011 3:26 PM
Hello,
I have a 1972 Chevy 4x4 with original top loader 4-speed(granny gear) that is stuck in neutral. Went to shift from 2nd to 3rd last week....went into neutral and that was it!!
Any suggestions?
Thanks, Steve in I-DA-HO
Sounds like the shifter broke off. If you push down on the collar and turn it you can lift the shifter out and take a look. Don
I will try it Don...not a tranny guy by no means. Thanks and will post what I find. Thanks
How do I push it down Don? Can't be this difficult but I am trying not to break anything else ya know.
Thanks, Steve
Oh...what am I looking for once I get it off?
Got the shifter out and it is not broke. I can see where it sets in the little slots. Any other suggestions? Is it possible that the pressure plate collapsed and it is stuck in neutral? Thanks, Steve
Riding in the Passing Lane
Take a big screwdriver & put it in the hole & down into the opening in the rails. The slots. If it is in neutral all the slots should be lined up. Try to move one of the rails with the screw driver. Each on should go forward & back one at a time. 2 rails cannot be moved forward or back when another is.
1972 Chevy c10 Cheyenne Super
