2 members (J Lucas, lumbersawyer), 129 guests, and 1 robot.
Topics128,047
Posts1,055,538
Members48,424
#75832 04/02/2007 2:28 AM
I was at the junk yard looking for brake parts and ran across some dually wheels.
I need to replace my split rims, but these ones had something I didn't know about.
They were eight bolts, but every other hole had a crown on one side. The others had a crown on the other side.
What is that all about? And can one of those be used as a front wheel and what kind of lug nuts would you use?
1965 Chevy C-30 1-Ton
"Work like you don't need the money. Love like you've never been hurt. Dance like nobody's watching."
#75833 04/02/2007 6:06 AM
what were the wheels on? as long as you get a set of chevy, i don't thinks it should be a problem, one thing to think of it to see how wide your tires are now, and you may not want to go much wider, because they could rub. i am in kansas city also, what yard were you at? if you don 't mind driving your truck to the yard, get the wheels, and test them make sure they fit over the drums, and clear things before you buy them. most yards will let you do something like that. i was at a farm auction this weekend and the sold dual rim sets, i don't think they brought 25.00 for the set, but look around at different yards, i was going to put duals on my 49, and some yards wanted 50.00 a rim, and others 25.00 a rim
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
#75834 04/02/2007 1:18 PM
Riding in the Passing Lane
Those are called "coined" wheels. Ford used them. I don,t think they will work on a Chev.
Are you guys comeing to the Woodlands swap meet on the 14th? I,ll be at booth A1017. Come by & say Hy. George
1972 Chevy c10 Cheyenne Super
#75835 04/02/2007 4:30 PM
My guess is that the coined area was meant to act as a way of keeping the face area of the wheel from making full contact. That would help with the problem of the wheels rusting on the face area. I don't know this to be the case but it seems logical to me.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#75836 04/02/2007 9:31 PM
They are coined every other one in the oppisite direction. They still fit flush up against each other. There is a recess in the drum also to acomodat them. That why you cannot use them on a Chev. They must be put on correctly with the valve stems opposite each other.
#75837 04/05/2007 5:17 AM
Junior Member
Junior Member
2 Offline
Sablesurfer,
I bought 6 rims and tires for my 64 C-30 Stake at a junk yard here in Las Vegas. They were on a wreck 84 or 85 1 ton chevy dually pickup. They worked just fine.Had to pay $350 for the 6 of them but the tires have at least 80% tread.
You will not believe the difference in handling and ride after you make the change to radial tires.
