3 members (cmayna, HandyAndy, 55shaker), 78 guests, and 3 robots.
Topics128,148
Posts1,056,810
Members48,454
Hi, I just got a 261 and i've started tearing it apart. This seems like a silly question, but how do i take the oil pump out? I unscrewed the line from the oil pump back into the black, and it won't come out. So, i figured i'd just take the whole pump out. It looks like its held in with 2 bolts through the block, but i cleaned off the head of the bolts and they have round heads! How do I get these suckers outta here!? Thanks!
1955 Chevrolet 210 2 door Sedan
a 30,000 mile UNMOLESTED original, now my daily driver! Original 6 cylinder with a rebuilt '66-'69 Saginaw 3-speed Overdrive. Synchro low! Otherwise, everything original down to the spare tire. Interior is like new. Needs paint, but absolutely zero rust.
To remove the pump, you need to loosen the bolt/nut on the inside of that bracket, not the 2 "bolts" on the outside of the block. If you remove these you will only make more problems for yourself in trying to get the pump and distributor to line up.
Get yourself a manual, also.
It's also easier if you remove the distributor first. And get a factory service manual, $30 investment that will save you a lot of time and money.
Fred
52 3600
69 C-10
You would remove it the same way as a 235-CAREFULLY, after reading your said 30.00 service manual, and 1961-62 suppliment.
