2 members (tclederman, Peggy M),
84
Mod | | | Forums66 Topics128,175 Posts1,057,052 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 35 New Guy | | New Guy Joined: Jan 2011 Posts: 35 | I am restoring a 54 3/4 ton chevy truck, frame up. My question is should I replace the clutch disk? Everything is apart so it will never be easier. The old one seams good but having never seen one before I really don't know. I will replace the throw-out bearing. Appreciate your advice.
Brimmer | | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | If the lining is anywhere near the ribbits you should replace it.
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | YES! Replace the entire clutch assembly. It should be around $200, and is well worth it for piece of mind. Keep the old assembly if you like. Now would also be a good time to have the flywheel resurfaced. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you drove it before you tore it down & it worked good I would take a hard look at it.If the lining is about 1/16 above the rivets, the springs in the disc are snug, 7 the fingers are even on the pressure plate I would reuse it. If you didn't drive it I would replace it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
