1 members (Cletus1950), 77 guests, and 2 robots.
Topics128,151
Posts1,057,000
Members48,460
I am restoring a 54 3/4 ton chevy truck, frame up. My question is should I replace the clutch disk? Everything is apart so it will never be easier. The old one seams good but having never seen one before I really don't know. I will replace the throw-out bearing. Appreciate your advice.
Brimmer
If the lining is anywhere near the ribbits you should replace it.
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
YES!
Replace the entire clutch assembly. It should be around $200, and is well worth it for piece of mind. Keep the old assembly if you like. Now would also be a good time to have the flywheel resurfaced.
Riding in the Passing Lane
If you drove it before you tore it down & it worked good I would take a hard look at it.If the lining is about 1/16 above the rivets, the springs in the disc are snug, 7 the fingers are even on the pressure plate I would reuse it. If you didn't drive it I would replace it.
1972 Chevy c10 Cheyenne Super
