0 members (), 132 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#75722 03/30/2007 8:28 PM
In my 53. 3/4 ton the greese in the steering box is old, and only 1/2 filled. Is there a way to "clean" it out and what should I refill it with? Read some about Lucis Oil any comements? And will this help with easer steering???? Thanks Paul
PJP
#75723 03/30/2007 9:31 PM
That question has appeared many times and the concensus is that plain old chassi grease is a good bet for old steering boxes, especially ones that leak a little. Flushing with keresene or parts cleaner is the only way I know of to "clean" one out. The fancy high end lubricants won't do anything more except lighten your wallet. There are tons of us Tri-Five guys using grease.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#75724 03/30/2007 9:58 PM
i mixed 80/90 gear grease with wheel bearing grease to get a thick lightly liquid consistancy . seems to have worked & it is not dripping out . frank
#75725 03/31/2007 1:12 AM
I use Alemite Hi-Temp #2, part # 9025-01.
Bill Burmeister
#75726 04/02/2007 5:00 AM
Penrite Steering gear Lube .
#75727 04/06/2007 8:42 PM
I second the Penrite suggestion. It's hard to find but works great. When I put 90 wt in it leaked out.
#75728 04/07/2007 2:08 AM
penrite is avail. from restoration supply company in escondido ca.---restorationstuff.com.nice people.
#75729 04/09/2007 8:19 PM
GM used to sell manual box lube but quit a few years back. It was always much heavier than 90 wieght. Some folks say that standard weight grease will not "flow" into the right places in the steering box components. (There is a term that I can't remember for this.) Penrite is the stuff that most folks say is the best, but is made in Europe and hard to find. The other often recommended product is John Deere Corn Head Grease. I got some at local dealer Deere Dealer for about $3.00 a tube. Seems to work fine.
1950 Chevy 3100
261, 4 speed
Purchased 1977
1964 Pontiac Lemans Convert
#75730 04/09/2007 9:53 PM
I use regular gun grease and a little Justin Brothers fritcion modifier in my 65 ton and after a couple of weeks it steered like it had power steering, used the rest in the old SM420 and it shifted a lot easier.
You Learn more Listening than Talking
#75731 04/10/2007 2:38 AM
donot use gun grease as it will not lube all it will cavity out on you,,if you think the sector has gun grease in it add some 10wt oil and hope it will get some of the hard lube flowing....A note to all you lovers out there if your steer box leaks go to a John Deere dealer and get a tube of cornhead lube it will flow and seals have to be very bad before it will leak out...doc
