6 members (55shaker, Wickedbass, FAST55, rfs56trk, Hotrod Lincoln, Hanks custodian), 57 guests, and 3 robots.
Topics128,065
Posts1,055,868
Members48,428
Are starters on the 216 and 235 engines interchangeable? The 235 engine is a babbit from a '53 chevy 1 ton pickup. It needs a starter.
3B Offline
Hy Colorado51three-
quarter, The quick answer is yes, as long as the engine is setup for the same voltage as the starter you're going to use. The two different voltage starters use different flywheels [ different number of teeth], hope that helps.
There is some good info about this from Patrick's. Look in the Tech Tips for the 216 to 235 swap. 3B is correct about the flywheel. You will need a 139 tooth flywheel from your 216. Check out a prior posting I made on this topic
My 1941 in the Stovebolt Gallery
My Photo Album
But I tried, didn't I? ... At least I did that. RP McMurphy
The past belongs to the future...but only the present can preserve it.
Besides the noble art of getting things done, there is a nobler art of leaving things undone.
I'm using a '50 216 starter on my '62 261. I had a machinist grind down the 261 flywheel so it fit the '50 ring gear and it worked out great. I kept the 261 flywheel so I wouldn't have to give up the 11" HD clutch.
Paint & Body Shop moderator
i bolt a 56 chevy 235 starter on my 216, i changed over to 12 volt,(was screwing off one day and cracked my starter houseing) i never changed the fly wheel, had no problem it works and has been that way for 3 years. and i know the starter i messed up was the original, as is my motor
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
