| | | Forums66 Topics128,080 Posts1,056,291 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Hey guys, I finally have my 61 Apache 10 properly registered and on the road! I am so happy...haven't touched my Yota in a couple days now. It runs and drives incredible for being mostly original, but whenever I start off from a stop, I can't seem to do a smooth clutch to gas transition...it "shudders". I'm not bunny-hopping it, it just shakes. Once it's going its good. I'm really not concerned about it but just curious if you guys think it's maybe the clutch disc or something, or maybe I just haven't finessed driving this oldie yet.
I used to have a different 61 Chev, it's still in the gallery...not mine anymore though. It had a four speed as well, but it was a newer one (still really old though) and it had a 283. I didn't have this issue with that truck... | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes, it's a clutch issue, maybe greasy fingerprints or something misaligned - not being concerned will see it worsen soon enough to get your attention  Bill | | | | | Joined: Apr 2009 Posts: 108 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 108 | Did you replace the pilot bushing in the flywheel? | | | | | Joined: Nov 2008 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 153 | The clutch is probably fried. Once you get it apart, chances are you will find that the clutch has been slipped a few too many times, and the fly wheel will need to be turned and all new parts installed (pressure plate, disk, and pilot bearing) Not a big job, and the end result will be a nice smooth start again! Good luck! | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Oil on clutch. You can try cleaning. | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | Another common problem is a bent clutch disc, if alignment pins weren't used during the last installation, it's easy for the installer to become fatigued and allow the transmission to hang from the pilot shaft, bending the plate. Alignment pins are easy to make. Just cut the heads off the proper size bolts and cut a slot in the ends to allow installation and removal with a large screwdriver. They support the transmission in alignment and make the whole job easier. Here's a shot taken that last time I did a clutch install: [IMG]http://img28.imageshack.us/img28/7816/bellhousingbolts.jpg[/IMG]Worn out motor mounts can also cause clutch chatter, by allowing the engine to flop around during engagement. | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Thanks for all the responses...yeah it is almost like the clutch grabs too harshly...gets a little bit worse once it's been driving a while. I've changed a clutch before, sort of (I helped) A vehicle like this one should be fairly easy if I use a transmission jack, right? | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | and dont put it in back wards... Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Joker, ha ha, man that would suck! Just exactly what happens if a clutch disc is put in backwards? (not that I'm willing to experiment on this...)  | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | A bad spring in the clutch plate will cause it as will a bad pressure plate. Also check for wear in the throwout bearing fork.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | Joker, ha ha, man that would suck! Just exactly what happens if a clutch disc is put in backwards? (not that I'm willing to experiment on this...)  The spring pack in the hub of the clutch disc will be an interference fit with the pressure plate or the flywheel bolts, causing nasty things to happen. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | How about bad motor mounts? | | | | | Joined: Jun 2011 Posts: 8 New Guy | | New Guy Joined: Jun 2011 Posts: 8 | I know I'm going to have to do this soon, so I'll be watching to see what happens. | | |
