3 members (kbenz, JW51, Gib70),
168
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 92 | I have purchased a new tie rod and tie rod end rebuild kit along with new ball studs for my 3/4ton first series 55. All is going well except I cant seem to figure out how to get the ball studs out of the tie rod end. Should I be able to get it out through the threaded end of the tie rod end? I have the tie rod off completely and the tie rod ends off the tie rod itself and the cap and outer seat are already removed. All that is left is the ball, the inner seat, the stop and the spring.
I am at a loss as to how to do this and the replacement 3/4 ton tie rod ends are hard to find and expensive when found so I dont want to screw these up!!!
Whats down in the well comes up in the bucket, so watch who's KoolAid you drink.
| | | | | Joined: Feb 2000 Posts: 5,216 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,216 | To remove the ball from the sockets, you first have to remove the large cotter pin on the end of socket piece. Then unscrew the large threaded cap releasing the spring tension from the sockets. Take it all the way out along with the socket and spring if there is one. Then work the ball out of the holder and remove the remaining pieces untill you have a empty shell. This is a drag link, but the parts are the same. http://chevy.oldcarmanualproject.com/1929_54chevyparts/06/411.HTMJoe | | | | | Joined: Feb 2001 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 92 | Thanks, my fault!!!!! I was too afraid I was going to break/mangle something and when I hit resistance on one side, I assumed that there was no way that the ball would slip out of the slot. My mistake. It required some force to get the spring to "compress", but it slipped out with some effort. thanks for not making fun of me, at least not in the posts!  Tom
| | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | What is a good method to determine if the balls need replaced, or should you just do it when you rebuild the OE ends? Joe, I am impressed with the attention to detail and the metohd of "lappping" the balls to the cups. Seems like a nice touch. Cavebull | | | | | Joined: Feb 2000 Posts: 5,216 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,216 | You can tell the balls are out round just by looking. The shaft was worn on mine where the shell would ride against it, think of it rolled off center. Mine also had egg shaped balls, but then it was a heating plumbing truck out in mid Kansas for 40 years, so it was run hard!
The lapping paid off nice, it just wouldn't steering right before I lapped them.
Joe | | |
