| | | Forums66 Topics128,078 Posts1,056,057 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#75437 03/25/2007 11:29 PM | Joined: Jan 2007 Posts: 24 Apprentice | | Apprentice Joined: Jan 2007 Posts: 24 | Well my 64 has a rather bad oil leak, it looks to be coming from between the block and head, but is hard to tell, so i would assume a blown head gasket, but there isnt any oil in the coolant and no coolant in the oil which i thought would be a sign of a blown head gasket, can I still have a blown head gasket without these conditions? Well anyways Im going to replace the head gaskets, is this rather easy? is there a manual out there that would cover this. Im assuming its as easy as it looks, drain the oil, and coolant, take the valve covers off then the intake manifold, take the headers off, then im lost. any help would be apreciated. thanks in advance. | | |
#75438 03/25/2007 11:39 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Make sure it isn't the oil sending unit or the rear of the intake, 2 more likely areas of leakage. Brian | | |
#75439 03/25/2007 11:48 PM | Joined: Jan 2007 Posts: 24 Apprentice | | Apprentice Joined: Jan 2007 Posts: 24 | its not coming from those, looking at again im pretty sure its coming from the head gasket. | | |
#75440 03/25/2007 11:50 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | ohWOW,
WOW, working on a V-8! It's been awhile since I did this task, but I'm thinking you have to loosen the rocker arm adjusting nuts, swivel the rocker arms out of the way to reach some of the head bolts hidden between them. This also allows you to pull the pushrods out.
When you pull the intake you will have to pull the distributor too.
Do some extensive looking using Brake-Kleen and rags on your leak BEFORE you go nuts! As Brian points out above, this type of leak is very uncommon to be associated with a head gasket .
Stuart | | |
#75441 03/26/2007 12:09 AM | Joined: Jan 2007 Posts: 24 Apprentice | | Apprentice Joined: Jan 2007 Posts: 24 | ill give the brake cleaner a shot and see if i can find out where its coming from, hopefully I can try tomorow beacuse the next 2 weeks will be full of 14 hour days (I love the Army). Thanks for the help though. | | |
#75442 03/26/2007 12:35 PM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | Valve cover gaskets? And thanks for you service. | | |
#75443 03/26/2007 4:45 PM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | A very common leak point is the "S" shaped area at the rear of the intake manifold. There used to be a gasket for it but now it is common to use silicone to form a gasket. | | |
#75444 03/26/2007 9:04 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Don,t pull those heads. It,s very unlikely thats where it,s leaking. Wash it down real good & look for the leak. Like the guys have posted, check the back of the intake, valve covers, oil sender, or even the dist gasket. If it,s comeing from the clutch/converter cover it could be a rear main seal. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#75445 03/27/2007 3:43 AM | Joined: Jan 2007 Posts: 24 Apprentice | | Apprentice Joined: Jan 2007 Posts: 24 | I was hoping to find the leak today but central texas got hit real hard with rain, so I didnt get to it, but I will mention that the oil is coming from the pass. side towards the rear. most of the oil is below the header, but theres a little above it, it didnt leak as bad as it does now before I changed the oil, but now when its running it pours out, all of which lands on the collector then turning into smoke. thanks again for the help. | | |
#75446 03/27/2007 2:10 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | If you are talking V8 you most likly have a intake leak where intake,head and block all meet that in the corner,,you state leak is on pass side so check dist gskt also and don,t forget the valve cover...doc | | |
#75447 03/29/2007 1:19 AM | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Wow.Don't be in a hurry to pull the head.I'm agreeing with the others here.Keep cleaning and checking the intake.A vacum leak will suck a surprising amount of oil.The rubber gasket at the back of the intake,as allready mentioned will leak too.Pulling the intake is way easier.I can't see, in my mind,that amount of oil between the block and the head. | | |
