3 members (tclederman, Otto Skorzeny, 1 invisible), 116 guests, and 0 robots.
Topics128,076
Posts1,055,920
Members48,429
#75437 03/25/2007 11:29 PM
Apprentice
Apprentice
Well my 64 has a rather bad oil leak, it looks to be coming from between the block and head, but is hard to tell, so i would assume a blown head gasket, but there isnt any oil in the coolant and no coolant in the oil which i thought would be a sign of a blown head gasket, can I still have a blown head gasket without these conditions? Well anyways Im going to replace the head gaskets, is this rather easy? is there a manual out there that would cover this. Im assuming its as easy as it looks, drain the oil, and coolant, take the valve covers off then the intake manifold, take the headers off, then im lost. any help would be apreciated. thanks in advance.
SGT Fraemohs, US ARMY
1964 C-10 short wide
#75438 03/25/2007 11:39 PM
Make sure it isn't the oil sending unit or the rear of the intake, 2 more likely areas of leakage. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#75439 03/25/2007 11:48 PM
Apprentice
Apprentice
its not coming from those, looking at again im pretty sure its coming from the head gasket.
#75440 03/25/2007 11:50 PM
ohWOW,
WOW, working on a V-8! It's been awhile since I did this task, but I'm thinking you have to loosen the rocker arm adjusting nuts, swivel the rocker arms out of the way to reach some of the head bolts hidden between them. This also allows you to pull the pushrods out.
When you pull the intake you will have to pull the distributor too.
Do some extensive looking using Brake-Kleen and rags on your leak BEFORE you go nuts! As Brian points out above, this type of leak is very uncommon to be associated with a head gasket .
Stuart
#75441 03/26/2007 12:09 AM
Apprentice
Apprentice
ill give the brake cleaner a shot and see if i can find out where its coming from, hopefully I can try tomorow beacuse the next 2 weeks will be full of 14 hour days (I love the Army). Thanks for the help though.
#75442 03/26/2007 12:35 PM
Valve cover gaskets? And thanks for you service.
#75443 03/26/2007 4:45 PM
A very common leak point is the "S" shaped area at the rear of the intake manifold. There used to be a gasket for it but now it is common to use silicone to form a gasket.
#75444 03/26/2007 9:04 PM
Riding in the Passing Lane
Don,t pull those heads. It,s very unlikely thats where it,s leaking. Wash it down real good & look for the leak. Like the guys have posted, check the back of the intake, valve covers, oil sender, or even the dist gasket. If it,s comeing from the clutch/converter cover it could be a rear main seal.
1972 Chevy c10 Cheyenne Super
#75445 03/27/2007 3:43 AM
Apprentice
Apprentice
I was hoping to find the leak today but central texas got hit real hard with rain, so I didnt get to it, but I will mention that the oil is coming from the pass. side towards the rear. most of the oil is below the header, but theres a little above it, it didnt leak as bad as it does now before I changed the oil, but now when its running it pours out, all of which lands on the collector then turning into smoke. thanks again for the help.
#75446 03/27/2007 2:10 PM
If you are talking V8 you most likly have a intake leak where intake,head and block all meet that in the corner,,you state leak is on pass side so check dist gskt also and don,t forget the valve cover...doc
#75447 03/29/2007 1:19 AM
Wow.Don't be in a hurry to pull the head.I'm agreeing with the others here.Keep cleaning and checking the intake.A vacum leak will suck a surprising amount of oil.The rubber gasket at the back of the intake,as allready mentioned will leak too.Pulling the intake is way easier.I can't see, in my mind,that amount of oil between the block and the head.
