| | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | the turn signal lights on my '52 stopped working a few days ago. the system is a SignalStat 900 Sigflare and I just replaced the heavy duty flasher fuse and both light bulbs - now what? any ideas on what to try to get this thing working again? | | | | | Joined: Jul 2010 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 36 | Just a possibility. Have you checked your ground? The unit grounds by contact to steering column. My column bushing is bad at the dash, so I guess my column wasn't a good ground path anymore. Of course, mine resulted in a blown indicator bulb in signal unit & a smoking wire. I ran an extra ground added fuse & everything is OK now. | | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | I haven't checked the ground. How would I go about confirming good contact via the steering column? continuity tester between the column and the frame? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You need to start with a test light. See if you have current from the flasher to the switch. If so see if you have current going to the respective lights. You also should have current to the switch from the stop lights when you press on the brake. The switch does not have to be grounded except for the pilot light in the switch. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | You need to start with a test light. See if you have current from the flasher to the switch. If so see if you have current going to the respective lights. You also should have current to the switch from the stop lights when you press on the brake. The switch does not have to be grounded except for the pilot light in the switch. sounds good! i'll do that and report back (never used a test light before... i'm a noob) | | |
