3 members (1955 1 Series, LAROKE, Otto Skorzeny), 80 guests, and 3 robots.
Topics128,086
Posts1,056,331
Members48,442
TURN ON THE darn GAS BEFORE YOU ARC ONTO YOUR PATCH PANEL !!!!!!
Nuff said?
"Happiness equals reality minus expectations" - Tom Magliozzi
Ex Hall Monitor
Ex Hall Monitor
That's funny JB! Bet you don't forget that lesson eh???
Y
Y Offline
Splatter spray won't prevent that? LOL
Always do a pratice on a piece of scrap before attempting to do it on the truck. Unless you are sure of yourself.
I always, leave the wire tensioner off the wheel and pull the trigger to fill the hose to nozzle, when I first turn on the welder and gas.
When I turn off the gas, I also disconnect the ground clamp on the work. That way I can't strike an arc if I forget to turn on the gas.
1951 1 Ton Completed
I hang my helmet off the gas reg. when I shut the gas off ,than when I get ready to weld I grab the helmet off the reg. and turn the gas on.That way I don't forget to turn it on or off.Getting older is a trip!!
Pete
Y
yar Offline
Y Offline
Jim Bow, what happens with mig and no gas? I have only oxy-acetylene, stick and tig. With tig it turns the tungsten yellow and makes a nasty mess in aluminum and stainless if there is no gas.
Ray
My experience when I have run out is a lot more splatter and an ugly weld.
Chuck
Lots of splat, and i burnt a hole.
I like the reminder methods. Thanks
