6 members (Gdads51, dt235sd, papas52, Bruce 1954-4100, tclederman, Forty9), 127 guests, and 1 robot.
Topics128,111
Posts1,056,258
Members48,437
Lookin for a template or measurements, to put out on the deluxe fender trim for a panel. Thanks in advance
Perro
1952 Chevy Suburban
1964 Chevy Suburban
1965 Chevy Suburban 4X4
1941 Chevy Truck
1948 Sedan Delivery
2000 K2500 Suburban
2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
Y
Y Offline
How would you suggest one make a accurate template? I have the rear fenders. I know theres a lot of holes to cover.
Y
Y Offline
Did you get my E-mail with pic's? Sent it out yesterday.
Not sure how to make a template, Just hoping someone had one. I have found some very valuble info here.That i thought was not available or known etc. And no I did not receive an email. Here's my email
[email protected]
Randy
1952 Chevy Suburban
1964 Chevy Suburban
1941 Chevy Truck
1948 Sedan Delivery
2000 K2500 Suburban
2008 K1500 Suburban
Y
Y Offline
I'll resend. I can tell you the trim consist of 3 rows spaced 2 1/4" apart. They are set out on a level plane, the top row is 12 1/2" up from the bottom of the fender @ the wheel well opening.
What I measured is the distance between the row of "holes" hope you got the pics? I still might be able to make you a template.
You might want to check that spacing again. I just went down and measured mine and theyre 3/4" apart. Thats in between each piece.
Theyve been on my truck since day one.1954
If needed, i can send pics to your e-mail.
I have what appears to have been an NOS fender on the left rear of my 1 ton panel. It has all the holes in it. I could do a rubbing on it so you could lay it out that way. I think they are slightly oblong but I'd have to look to verify.
Just here for the free beer.
1953 1-Ton Dump Truck
1954 Teenage Hot Rod
I have just scored a set for my burb. I would like dimensions or a template if possible also. Thanks in advance.
Wish I could score a set for my burb..booo
