2 members (BC59, Bill Hanlon),
152
Mod | | | Forums66 Topics128,088 Posts1,056,109 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 35 | Someone put some aftermarket chrome dipstick in my 235 on my truck. (the engine is a 58-62 vintage from what I gather).
Its way too long and actually hits the bottom of the pan before going in all the way. Want to know how long the correct one is. Can someone measure it from say the part that sits on the tube to the very end and from the very end to the low and full marks?
Thanks!!
1950 3100 Project-just getting started
| | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Duwem mine is 15 1/8 in long, the part that goes from the top of the tube into the engine... 13 1/4 to the top of the FULL LINE 13 3/4 to the ADD LINE ... My tube is 7 1/4 long from the block upwards ... Same 58-62 vintage engine ... Block cast # 3769716 ...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | The dimensions Healingbear gave you may work just fine in your application. However, the tube that the dipstick goes into may have been replaced or driven into the block deeper or shallower than standard and will not necessarily register the oil level correctly. The safer course of action is to drain your oil and add 5 quarts of fresh oil. Where the top of the oil sits is your full mark. You could also stop at 4 quarts and mark I quart down.
I am using a stock dipstick and adjusted the tube (a piece of brakeline) length to correctly measure the oil level according to the dipstick.
Chuck | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | What Hookalatch said. Cut it to length then change your oil and mark your quart low and full marks as you put the new oil in.
| | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | And not to hyjack the post, but where to get a new dipstick?
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | One way to find a dipstick is to figure out what approximate length you need and then Google (or Yahoo, or Bing) "dipstick". | | | | | Joined: Oct 2010 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 35 | Thanks guys! Like mentioned, the best will probably be to fill it up to 5 quarts, mark low then top it off to 6 and mark full. Do I need to confirm what pan I have or would they all be the same regardless of what the engine came from?
Newbie question, what weight and brand oil works good in these engines? Again, mine is a 30psi pressure lubed 235 from what I can tell. There is an oil pressure gauge in the original cluster hooked to the engine that reads around 30psi.
| | | | | Joined: Oct 2010 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 35 | What weight oil should I run in this engine?
Will get driven from 40-90F temps.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | A modern 10-30 or 10-40 should work OK. I personally run 15-40 in my '38.
