| | | Forums66 Topics128,185 Posts1,057,274 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 | Are there a lot of difference in the 41-46 rear fenders and ones on trucks of the late thirties? Doing a google search online the pictures look about the same. Anyone swap these out and make em work? Thanks, Chris.
Chris Simmonds 1942 Chevy 3/4 ton | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | The 38's were used on the 40's 1Tons. Looks good to me. | | | | | Joined: Dec 2004 Posts: 23 New Guy | | New Guy Joined: Dec 2004 Posts: 23 | I believe 39 and 40 fenders are the same as 41-46 fenders except they are wider. This is because the box on a 39-40 is narrower. I've seen Art Deco trucks with the earlier fenders on them to give an extra 2" of clearence for wider tires. The only problem is that the running board will not line up with the edge of the fender like it is supposed to if you go that route. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | 39 fenders are wider, 40-46 fenders are virtually the same, with differences in the bracing through the years. | | |
