4 members (pauld, klhansen, GradyB, 60steve), 197 guests, and 4 robots.
Topics128,204
Posts1,057,289
Members48,467
Are there a lot of difference in the 41-46 rear fenders and ones on trucks of the late thirties? Doing a google search online the pictures look about the same. Anyone swap these out and make em work?
Thanks, Chris.
Chris Simmonds
1942 Chevy 3/4 ton
The 38's were used on the 40's 1Tons. Looks good to me.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
I believe 39 and 40 fenders are the same as 41-46 fenders except they are wider. This is because the box on a 39-40 is narrower. I've seen Art Deco trucks with the earlier fenders on them to give an extra 2" of clearence for wider tires. The only problem is that the running board will not line up with the edge of the fender like it is supposed to if you go that route.
39 fenders are wider, 40-46 fenders are virtually the same, with differences in the bracing through the years.
