1 members (Hotrod Lincoln), 41 guests, and 0 robots.
Topics128,035
Posts1,055,560
#752021 06/04/2011 7:31 PM
I have the cab and fenders in epoxy primer, and i've started to wet sand with 400 grit. What should the surface look like and feel when i'm done? Am i right in asssuming that the surfacer does not need to be sanded? Thanks.
watsjoe #752026 06/04/2011 8:15 PM
Y
Y Offline
The unsanded primer will have some "texture" and after you sand, it should "feel" smooth/slick. Surfacer?, are you refering to sealer?, yes it don't need to be sanded unless you wait to long before you apply color coat. Tip if you wipe down the surface with grease/wax remover after sanding, any defects will really show up.
