| | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | I have the cab and fenders in epoxy primer, and i've started to wet sand with 400 grit. What should the surface look like and feel when i'm done? Am i right in asssuming that the surfacer does not need to be sanded? Thanks. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | The unsanded primer will have some "texture" and after you sand, it should "feel" smooth/slick. Surfacer?, are you refering to sealer?, yes it don't need to be sanded unless you wait to long before you apply color coat. Tip if you wipe down the surface with grease/wax remover after sanding, any defects will really show up. | | |
