7 members (1955 1 Series, klhansen, J Lucas, Otto Skorzeny, Bill Trotter, cmayna, Wayne67vert),
97
Mod | | | Forums66 Topics128,185 Posts1,057,205 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | Looks awesome! I know what you mean about the stovebolt community and the help and assitance offered. My wife does alot of airbrushing and pinstiping. When the truck is completed, I plan on having the names of everyone involved with the restoration, be it local or abroad, painted on the inside of the glovebox door. I have to get either a bigger glovebox door or use really small lettering.
Keep us posted. ~Ron | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Today's update: just a couple of pictures of parts I've aquired in the past weekend. A Crouse-Hinds 17" spotlight and Stovebolt member Grigg's donated checkerplate steel tank which I'll cut up to replace the rear step on the fire truck.
Thank you everyone for all the assistance as I couldn't get it done without you all.
| | | | | Joined: Jun 2005 Posts: 209 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 209 | Nice looking rig. Its all in the details and it looks like your on your way. Keep plugging away. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Thanks. We got it started and running on Friday. Next: It will be getting the rest of the body finished and installed in the coming months. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | New 825x20R tires go on. Also had remove the exhaust manifold as it was leaking. Sent to to be machined. Hopefully it will be done this week and we're off to get the body work finished.
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Update: I took the truck over to the fabrication shop to have the water tank and hose bed installed. The best part was I drove the truck! The exhaust manifold is leaking and I have a fix on the way but atleast I have driven the truck. thank you everyone for your assistance. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Yippee it has been a journey that I have enjoyed watching you make. You have brought true glory to that old truck. I want to see it putting water in the air on a sunny day making rainbows.  | | | | | Joined: Nov 2000 Posts: 1,972 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,972 | Looks great. I have not read every word of this thread or viewed all of the pictures but I did study one of the motor pics and is that a 261? I thought I saw the captain's bars above the starter. Good luck.
Professional Novice
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Thanks. It would not be possible without the advise and input of the Stovebolt members.
Yes it is a 1959-1962 261 motor. We do not know when that was changed out from the 235 that was originally in the truck.
And it will be flowing water in the air and making rainbows by summer time! | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Virginiafiretruck,
Regarding your 17" spotlight...what is its voltage and what powers it? Is there some power source on the truck it plugs into.
Stuart | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I do not know. It has a 12 volt bulb and plug on it but I have not plugged it in out of fear of burning it out. That large size bulb has to cost a small fortune. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Dash installed, exhaust/intake manifold not leaking anymore as the end studs were removed and new bolts and thick gasket installed.
Thanks again for all the help. Next, I'm going back to look at the thermostat.
| | | | | Joined: May 2006 Posts: 89 Shop Shark | | Shop Shark Joined: May 2006 Posts: 89 | Hey Firetruck! She looks REAL nice! You've done one heck of a job! I have a question, though. Do you happen to remember the number of the dry air filter you used and the measurement of the original oil bath housing? I did a search for info and found the "Great Debate" interesting, but didn't see where anyone listed a number for the K&N or Fram or anything else! Thanks! | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Thanks. The filter is a "Wix Filters" part number: 42011 I can measure it on Thursday when I get down to the garage.
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | New radiator installed and truck out in the sun and daylight as i took it for a spin around the block a few times:
Thanks to the Stovebolt's for all your help and knowledge with the thermostat, radiator and cooling system. FYI: I have already given the old 261 thermostat housing to another member for his use on his truck so I don't have any longer. Sorry but I'm sure he'll put it to good use!
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Recently, you all have helped me with the radiator replacement, carb rebuilding and float adjustment and last but not least, the thermostat housing replacement and the total cooling system. There was also the new exhaust manifold gasket and bolt down system.
Once again without you all to help, I'd be lost. And I'll add that I'm glad I'm learning this stuff now rather that in some parade with a bunch of civic leaders and Boy Scouts riding in the hosebed! Thanks again everyone.
| | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | looks great, now you can open your own private fire department  1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Thanks. Today, they(I'm not a welder) started working to install the water tank and new hosebed!!! Once that is in, we're almost finished. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Steel hosebed and water tank being installed. It will be finished by lunch on Friday. Then it is back to have the rest of the body work done and be finished painting!!!! I'm starting to see the light at the end of the tunnel...hope it isn't a train.
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | It was Snowing here in Virginia Beach today, so I couldn't move the firetruck back to the body shop so I started on a new project:
Those things are not climbable but they will look good and work just fine on the side of the stovebolt. Who knew that 55 years later the ladders would still look good?
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | The Truck is back to it's final stop: The body shop!
Latest photos include the water tank, hosebed and the "checkerboard steel" rear step. The step material was donated by Stovebolt member "Grigg" when I was hunting for replacement steel plate. Thanks Grigg!
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Thats going to be one pretty truck. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Thanks! I hope to put the truck in a car & truck show (locals) on May 5th. Today, I sanded one side down to the bare metal so we can prime and begin painting. I've got to work at the firehouse so the rest will have to wait until Friday.
Also, I discovered the old gold leaf pinstripes as the layers of paint came off.
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | It was raining all day long in Virginia Beach so there`was nothing to do except work on a finishing some fire truck parts.
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Update: Today I removed the grille bars and began to restore the doors. The glass was easier to remove than I expected but you gotta have a clutchead screw set! New pictures online also...
| | | | | Joined: Jun 2006 Posts: 382 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 382 | Originally posted by HevyHauler: Thats going to be one pretty truck. I agree!  | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | A couple of questions. I assume you re-built the Hydor-Vac unit. How bad was that?
I also noticed the good shot of the famous 'captain's bars'. My engine definitely does not have those, so its not a 261.
Did you have the speedometer and gauge cluster done or did you do them yourself. They look fantastic. I haven't been able to find any 0 - 60 oil pressure gauges. I'm really hoping that my 235 is pressure lubricated, but I can't possibly be that lucky. Does the presence of the oil filter mounted on the intake manifold have any significance?
BTW, I pulled the carburetor off last night. I should have taken a few pictures. I'd been trying to figure out why it had to hose clamps around the carburetor base. It was obvious when I got them off. A piece of the carburetor mounting base fell off. Somehow the part between the engine side mounting stud and the engine got knocked off. I appreciate them keeping it, but I doubt that it was performing any structural duties.
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | 1) I had to remove the old one and purchased a rebuilt hydrovac from the local NAPA auto parts dealer. It was easier that taking it apart as I have never worked one of those things before.
2)I had the old "Chevy Duty" folks rebuild the gauges so no I didn't do those myself. They do look great but remember to keep the 2 speed rearend cable adapter and the 1' piece of speedometer cable with you rather than sending it with the gauges to be rebuilt. I didn't know it but that was going to be a mistake that would come back later to haunt me.
3) As for your carb mounting base: It might be the insulator part that broke as those thing crack with age. You can buy one of those from any Stovebolt parts store online or in your community. Your carb might still be intack.
Today, I pounded out a couple of dents in the fenders of the fire truck and obtained the wood decking for the hosebed part of the rig. I wanted to cut and fit the wood before the area was primed and painted as I thought it might damage the new paint if I waited for the paint job to be finished. Anyway, I've added a few more pictures from today. Thanks again for all the help!
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | stripped the rest of the hosebed, booster hose reels, added a checkerboard steel trim piece to the rear of the truck. Getting ready to prime and paint the rest of the truck. Vent window trim has been striped of glass also. It is starting to get exciting! BTW: Thanks to stovebolt members who have provided several motor compartment parts in the past week. Thanks again for all your assistance!
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I was looking at the pic of the engine compartment. Do you have a vacuum line going to the wipers or are there some sort of electric wiper? I see what looks like a galv pipe, but no tee going to the wipers. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Yes. That pipe is the distribution point for vacuum lines to the wipers, hydrovac and 2 ton rear rear end. It all comes together on the fire wall. For the wipers, it goes thru the firewall and on to the vacuum operated wipers. I have heard from folks who recommend I put in electric wipers but if the originals work, I stay with them. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I have seen adds in Hot Rod for add-on vacuum reservoirs for cars with large cams that don't make enough vacuum. One of these could make a big difference if you have vacuum problems. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Thanks. I haven't tried the wipers on glass or in the rain except to see if they move since the rebuild started. I hope not to ever use them again but they'll have to work to pass inspection. The window glass will be going in soon and then I'll see if they work.
etch primed parts and truck steel and first coated the rest of the truck body.
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Great it’s coming along nicely. So when's the parade it will certainly draw a crowd.  | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I love a parade!!! Anyway here is the update for today: Block sanded lots of steel & primer, sandblasted window frames, door parts and other stuff getting ready to paint. Added a fuel line clamp that I obtained from a member of the SB web site! Thanks again.
| | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | Enjoyed that show. You're in the last 6 of a marathon... | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Wow,A real nice truck !! You are on a roll, so keep up the good work !!!
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Thanks. I'm trying to get it finished so I can drive it!!!! Seems like it takes years just to get one thing finished... | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I was making killer progress for a wile now every thing seems to have stopped so watching yours come together as it rounds the home stretch is a thrill for sure. I think I may put my big block in the 64 when I get it because that is the one that I am using and I sure ask a lot of that tired old 350 that's in it now. | | |
