2 members (2-Ton, Bill Hanlon), 82 guests, and 3 robots.
Topics128,142
Posts1,056,485
Members48,441
I have looked all over trying to find the rubber to go under the SS strip on the center of the windshield. I can find it in "kits" with the strip, but I only need the rubber.... Ideas on where to get some??
I'm also looking for rear fender braces if anybody has any....
Thanks! Monica
Monica
Be the change you want to see!
what year? make? model? Assuming you are talking about a 47 -54 AD it is part of the rest of the windshield rubber.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Sorry frown It's a 52 AD - When I put the center strip on, there is a gap between the rubber and the strip. I've seen "kits" that sell the SS strip and rubber piece to go with it, but I just need the rubber piece to place between the windshield rubber and the SS-strip.
Monica
Ex Hall Monitor
Ex Hall Monitor
Thanks, I'll try them smile
Monica
The center rubber strip is, as mentioned previously, part of the entire rubber gasket.
The space you are referring to is probably where the outer steel bracket that goes
between the SS strip and the rubber. On the inside, there is another steel strip
the whole works is a "sandwiched" affair that draws the SS trip in when the proper
ling screws are tightened.
Hope this helps
mike
Ok... I've got the steel bracket on the inside but not on the outside.... that must be where I screwed up frown I knew something "had" to go there, I just thought it was another rubber pc. I didn't have a complete truck to start with so it's been kind of though trying to figure some of this out...LOL
Thanks for your help!
Monica
