9 members (Otto Skorzeny, 52Carl, cmayna, klhansen, joe apple, Hotrod Lincoln, Peggy M, 2 invisible),
156
0
Mod | | | Forums66 Topics128,114 Posts1,056,282 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | TURN ON THE darn GAS BEFORE YOU ARC ONTO YOUR PATCH PANEL !!!!!!
Nuff said?
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | That's funny JB! Bet you don't forget that lesson eh???
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Splatter spray won't prevent that? LOL | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | Always do a pratice on a piece of scrap before attempting to do it on the truck. Unless you are sure of yourself. I always, leave the wire tensioner off the wheel and pull the trigger to fill the hose to nozzle, when I first turn on the welder and gas.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | When I turn off the gas, I also disconnect the ground clamp on the work. That way I can't strike an arc if I forget to turn on the gas. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I hang my helmet off the gas reg. when I shut the gas off ,than when I get ready to weld I grab the helmet off the reg. and turn the gas on.That way I don't forget to turn it on or off.Getting older is a trip!!
Pete | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Jim Bow, what happens with mig and no gas? I have only oxy-acetylene, stick and tig. With tig it turns the tungsten yellow and makes a nasty mess in aluminum and stainless if there is no gas.
Ray
| | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | My experience when I have run out is a lot more splatter and an ugly weld. Chuck | | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | Lots of splat, and i burnt a hole.
I like the reminder methods. Thanks
