BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
10 members (TUTS 59, homer52, Guitplayer, Hotrod Lincoln, 32vsnake, Charles in CA, Peggy M, 46 Texaco, 2 invisible),
556
robot. | Key: Admin,
Mod | | Forums66 Topics126,776 Posts1,039,271 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Jan 2002 Posts: 2,254 'Bolter | 'Bolter Joined: Jan 2002 Posts: 2,254 | How many cross sills are there under the wood of my bed?
I am thinking there is the front one and the one over the gas tank but am unsure if there is another.
TIA
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | Joined: Oct 2007 Posts: 63 Wrench Fetcher | Wrench Fetcher Joined: Oct 2007 Posts: 63 | see link at bottom regarding youtube video on bed assembly in there is string of photos one showing the bed sills in a 50 which I think would be the same. 4 in total. With mine I found the second sill in front of the rear axle was not fixed down? made my own tapered mounts all good
| | | | Joined: Dec 2005 Posts: 406 Shop Shark | Shop Shark Joined: Dec 2005 Posts: 406 | You should have one also behind the axle about 23 inches forward from the rear end of your boards. That one needs to have a bed to frame bolt go through it into the frame.
Mar-Ktech | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | 'Bolter Joined: Jan 2002 Posts: 2,254 | So. There are three in front of the rear axle and one between the axle and rear sil?
Thanks again
