Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
0 members (), 525 guests, and 1 robot.
Topics126,777
Posts1,039,270
Members48,100
Most Online2,175
Jul 21st, 2025
#748044 05/18/2011 6:21 PM
How many cross sills are there under the wood of my bed?
I am thinking there is the front one and the one over the gas tank but am unsure if there is another.
TIA
Dennis
U
U Offline
see link at bottom regarding youtube video on bed assembly in there is string of photos one showing the bed sills in a 50 which I think would be the same. 4 in total. With mine I found the second sill in front of the rear axle was not fixed down? made my own tapered mounts all good
You should have one also behind the axle about 23 inches forward from the rear end of your boards. That one needs to have a bed to frame bolt go through it into the frame.
Mar-Ktech
So. There are three in front of the rear axle and one between the axle and rear sil?
Thanks again
Dennis
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.049s Queries: 14 (0.046s) Memory: 0.6100 MB (Peak: 0.6476 MB) Data Comp: Zlib Server Time: 2025-09-22 08:00:21 UTC
Valid HTML 5 and Valid CSS
