4 members (J Lucas, Otto Skorzeny, Ponchogl, 1 invisible), 92 guests, and 2 robots.
Topics128,072
Posts1,055,903
Members48,429
#748996 05/22/2011 8:48 PM
I disconnected the battery cable while removing my gas tank and sending unit. Then, after reinstalling the tank and sending unit, I reconnected the battery cable. Now, the only guages that work are the mechanical ones, speedo and oil pressure. The temp, amp, and gas guages have stopped working. What do these guages have in common that could have stopped working all at the same time? Does anyone have any ideas about where should I start looking to correct this?
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
Ex Hall Monitor
Ex Hall Monitor
Bill will most likely be along shortly. I'm not familiar with the wiring on a '59 but it sounds like a blown fuse to me.
do all the other electricals work after this, ie the headlights, etc - and only the gauges quit?
You might check the connections at the ammeter and the ignition switch, notably the red heavy wires. It's very easy to knock them loose when working under the dash. I've done it many times myself on the '55.
Bill Burmeister
Yes, only the guages quit. Everything else works as usual. None of the work I did involved working under the dash.
Oldbolter
Check your fuses.
Dennis
All fuses okay, still no guages working. I appreciate the suggestions offered. My next move appears to be tracing each guage circuit until I find the problem.
Thanks everyone
Oldbolter
Make sure your grounds are good. I have found that to be problems before.
Dennis
Often when you go back to the last thing you did you find the problem. Is it possible you jiggled the terminal on the starter solenoid which in past was used as common point (source?) for all the hots? Corroded lug that got jiggled and gave up? Maybe checking any connection one connection away from battery may find your problem.
Dan Bentler
