1 members (Materman),
107
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | I disconnected the battery cable while removing my gas tank and sending unit. Then, after reinstalling the tank and sending unit, I reconnected the battery cable. Now, the only guages that work are the mechanical ones, speedo and oil pressure. The temp, amp, and gas guages have stopped working. What do these guages have in common that could have stopped working all at the same time? Does anyone have any ideas about where should I start looking to correct this?
Oldbolter 1959 Apache 3800 dually flat bed/dump with 261 1956 3800 dually flat bed/dump with 235 1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Bill will most likely be along shortly. I'm not familiar with the wiring on a '59 but it sounds like a blown fuse to me.
| | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | do all the other electricals work after this, ie the headlights, etc - and only the gauges quit? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You might check the connections at the ammeter and the ignition switch, notably the red heavy wires. It's very easy to knock them loose when working under the dash. I've done it many times myself on the '55.
Bill Burmeister | | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | Yes, only the guages quit. Everything else works as usual. None of the work I did involved working under the dash.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 |
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | All fuses okay, still no guages working. I appreciate the suggestions offered. My next move appears to be tracing each guage circuit until I find the problem.
Thanks everyone
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Make sure your grounds are good. I have found that to be problems before.
| | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | Often when you go back to the last thing you did you find the problem. Is it possible you jiggled the terminal on the starter solenoid which in past was used as common point (source?) for all the hots? Corroded lug that got jiggled and gave up? Maybe checking any connection one connection away from battery may find your problem.
Dan Bentler | | |
