2 members (ShopRag, 1 invisible),
145
Mod | | | Forums66 Topics128,283 Posts1,058,506 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | Sounds like you're making great progress Jerry...can't wait to hear about you firing it up!
My heater is apart and I'm getting ready to blast and paint it.
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Jan 2011 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 138 | Ospho-ed some rust peeking through on the tailgate, piddled with the gas gauge wiring, tried to adjust the parking brake and found everything is to rusted to tighten, drove it around the field, found out applying the brakes lights up the blinkers up front and the blinkers don't work on either the front or the back.
It was good to hear it rumble, though. But now it kinda sounds like one cylinder is not firing.... Another day....
Alex 57' 3100 (The Bondo Bandit) Bad rust and worse wiring, but so much fun.
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | The ‘53’s hood is painted and ready to install! Nice color.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Mar 2011 Posts: 86 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 86 | Got my two boys and a friend to get the cab off my 65.Wheeled the frame outside,to get the frame ready to power wash,and sandblast. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Tightned up the remaining bolts to finish and took her around the neighborhood for a 6.5 mile shakedown cruise. Started the frame off in 2006 finally done in time to enjoy her this summer.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Started mine in 06 as well and hope to have her roadworthy by June. Tonight I managed (remarkably) to rebuild the remote inside door handle. It was like trying to put a watch back together. Last night I ran the wires and hooked up the speakers and tested the radio, it worked. Tomorrow I plan on stuffing wires under the dash, keeping them organized and neat, and work some more on figuring out the headlights.
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Sounds like 2011 will a good year for maiden voyages! I'm currently at the one step forward,two steps back part of my build. Found out I will have to clear my centre crossmember for the driveshaft,as I found out the other day. I initially thought I might get away without doing it.  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Replaced the dimmer switch and put new hood bumper pads on. Measured the stock wheel backset - lookin' at some wheels and tires, trying to see if they will clear the tie rod ends. Pretty sure they will, now I just need to come up with some cash! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Bought a courtesy light cutoff delay from American Autowire along with two turnsignal dash lights and a highbeam light. Also put the first coat of clear urethane on the bed wood, two more coats to go.
~Jim
| | | | | Joined: Nov 2009 Posts: 33 New Guy | | New Guy Joined: Nov 2009 Posts: 33 | I managed to get the front disk brakes moved to the front side of the spindles to clear the new steering arms and I got the rack and pinion installed | | | | | Joined: Mar 2011 Posts: 11 New Guy | | New Guy Joined: Mar 2011 Posts: 11 | got desiel into cylinders today, carby sounds like it is pumping at least, spark plugs are black, no build up just black | | | | | Joined: Dec 2002 Posts: 3,447 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,447 | I put some more junk in the bed... I guess I'll have to clean it up soon and put the battery back in that I "borrowed" when I was having issues getting my Binder to start.
| | | | | Joined: Apr 2011 Posts: 8 New Guy | | New Guy Joined: Apr 2011 Posts: 8 | I sent mine to the shop to get frame work done. Having a subframe from a 76 Nova put up front and an S-10 rear end put under her. While its there will have the brakes done, fuel tank moved to under the bed and the rear cab corners replaced from where they rusted out. Once she's back she should be driveable and I hope to start on the interior. | | | | | Joined: Feb 2003 Posts: 1,391 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,391 | Put a one step bigger jet in the carb and greased all the fittings today along with the drilled head bolt,the valvetrain repairs are now done so its time to look into electronic ignition. | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | nothing done on the 50, but did wake up the 52 (fire truck) and drove it around and of coarse and to blow the siren and let the neighbors have a listen, | | | | | Joined: Jan 2011 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 138 | I fought the gas gauge today. I ended up rewiring the entire citciut, and giving it power directly from the accessory post of the ignition switch. Closer to the end of day, I narrowed it down to the actual gauge as the problem. So I gave the PO a visit who had a box of stuff from his cousins 55 for me. I then robbed everything but the temp gauge from the newly acquired instrument panel. And it worked! And looks better! I also got a steering wheel from a 55, tie rod and ends, heater controls, master cylinder, and what looks to be the entire wireing harness.
| | | | | Joined: Jan 2011 Posts: 90 New Guy | | New Guy Joined: Jan 2011 Posts: 90 | Mounted my replacement alternator Got a brand new chromed one with a 2 inch mounting spacer. Then putting a lazer pointer in the pully of the old 6 volt generator messured how much pully was from bracket. Did the same on the new alternator in reverse marked and cut the 2 inch spacer . Measured too make sure wasnt cutting into body of alternator ( 2 inch spacer is 1 inch cast into the body of the alternator and 1 inch over hanging supported by lighweight cast in webs ) cut back too correct measurement. Drilled holes on old bracket too take 8 1/2 inch piece of all thread, locked it into place using 3 nuts and washers. Slid alternator onto all thread secured with lock nut , took off old generator adjustment bracket flipped it over and matches new Alternator offset perfect. Put laser pointer in water pump grove and shone it on Alternator pully perfect alinement , Put Standard belt back on tightens up perfect , all secure and very solid. Am very happy with result and didnt cost anything too do
1954 3600 With 1950's Powers of St Louis Utility Bed. My truck | | | | | Joined: May 2011 Posts: 39 New Guy | | New Guy Joined: May 2011 Posts: 39 | My 61 Longbed had its Holley 600 carb borrowed to get the 283 in my 63 going. The 61 was settin for a week. Today I slapped on an old QJet that came on the 61's horrible 350 when I first got it. It's been sitting for a year. I was just going to use the qjet to move it into my garage so I could start on my 216 swap soon. To my total surprise, It runs well!  | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Still trying the get the doord adjusted right with the new weatherstripping. I'm really beginning to hate TF doors :mad:
Bill Burmeister | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Put the first coat of three on my topside bed boards. I've finished the underside and should be putting the bed together by Sunday evening. Also starting on, ugh, the weatherstrip.
~Jim
| | | | | Joined: Apr 2010 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 53 | installed new leaf springs front and rear, with new shackels, bushing and all managed to chip the freshly painted frame while swapping bushings  -LGringo
'54 chevy 3100. In pieces now. .... I've always liked puzzles -Gig em Aggies! Class of 2013
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | NOTHING TO IT!!!
All those horror stories about installing the cab windlace?? My son and I and a bottle of ivory liquid detergent took less than 10 minutes per door. First I cut a 2" piece and slid it through the tracks then I used a screwdriver to force open were needed. Not a problem!
~Jim
| | | | | Joined: May 2011 Posts: 39 New Guy | | New Guy Joined: May 2011 Posts: 39 | Well I helped my friend get his storage reorganized. Many parts, blocks and engines had to be moved out to get his 60 Impala with the 235 and overdrive I want out. That event went well into the night. I had to pull the flat tired Impala out with my 61 Chevy longbed. the glide and 2800 stall converter were not ideal for this. good thing my truck still has those 3.89 gears. We got stuff back in on shelves in the back and the car is now at the door facing out. Soon I will hear my future 235 run, and then pull it out of the Impala! xross your fingers it runs great for me... | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | Finally found the correct interior rear view mirror stem, got that on, took all of 5 minutes, I should be more motivated to keep going. | | | | | Joined: Jan 2011 Posts: 90 New Guy | | New Guy Joined: Jan 2011 Posts: 90 | Connected battery too cables and tested newly installed wiring loom , No smoke so far and everything working
1954 3600 With 1950's Powers of St Louis Utility Bed. My truck | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I pulled the ragged upholstery off the jump seat cushion in the burb and welded the broken mounts. Then put the ragged upholstery back on because SMS still hasn't got off their duff and sent the material I paid for April 8. I was hoping to have the upholstery done before driving to South Bend, but noooo. It will still have the Mexican blankets. | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Finally put our seat in! We broke down and got a Tea's seat. Looks great, expensive though! Oh well, can't take it with you!!! | | | | | Joined: Nov 1995 Posts: 5,762 24601 | | 24601 Joined: Nov 1995 Posts: 5,762 | After we got *the* Stovebolt back up and running (Baldeagle and I), I got the '65 Tanker out and watered Peggy's transplanted azealeas. Nothing like a fire hose in one hand and a Beck's in the other  Oh, and I reinstalled a water pressure gage on the pump right before I did that. The 66-year old Darley 500 GPM pump was making 90 psi without even breaking a sweat. JM
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | yesterday Myself and A neighbor (also a stovebolt owner) loaded my cab on a flatbed trailer and took it off to the sand blaster...cant wait to get it back!
*UNDER CONSTRUCTION* 1953 Chevrolet 3100 1/2 ton-previously abandoned resto. My Project BoltI hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Finished the third coat of urethane on the top side of the bedwood. Spent an hour or so on the wiring. Tomorrow or Wednesday night we will put the bed together.
~Jim
| | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | Today I put the original sway bar back in using all the original brackets, new rubber bushings. I also stood back and admired the truck, hoping to have it on the road soon. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Sent it to the air conditioning shop to finish out the hoses and freon. Next week I'll be towing it to Rich's Performance Muffler Shop ( http://www.richs-performance-mufflers.com/) for an X pipe set-up. Then it's to the county tax office for registration.
~Jim
| | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | Got my '52 registered. Reupholstered the seat last week. Pulled the wonky ranch-built bed. Will start construction on the wood flatbed this week. I'll be picking up loads of firewood in no time! | | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | Rebuilt drag link and tie rod ends on my 49' 3600. Waiting on the new king pins to get here.
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | Took delivery on my new air bag helper springs. I'm busier than an one-armed piano mover but took the time to remove my stock shock setup to make way for the new bags. | | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | Straighten out my LF. Door Piler and Primed it. Started to cut out my LF. Floor section, Side Kick Panel and Rocker Panel. Cutting brace bars to keep the Piler from moving and welding to F. Piler to R. Piler plus tying across F. to F. Piler too. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I got my Suburban ready for a road trip. New points, re-set timing, checked fluids and air in the tires. Tomorrow we head for South Bend. | | | | | Joined: Dec 2002 Posts: 3,447 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,447 | I sanded all four fenders with 100 grit paper, tapped down a few high spots and put on another coat of primer.
| | | | | Joined: May 2005 Posts: 119 Shop Shark | | Shop Shark Joined: May 2005 Posts: 119 | I changed rear end oil in the '72 c-50 | | |
