8 members (Otto Skorzeny, Bill Hanlon, Maybellene, 2-Ton, klhansen, carbking, Peggy M, Wayne67vert), 65 guests, and 4 robots.
Topics128,042
Posts1,055,497
Members48,424
#748763 05/21/2011 5:41 PM
Too often my truck will get stuck in 1st gear or won't shift into reverse. If I open the hood and manually pull the linkage to a different position it works for a while but I need a more permanent fix. My shift lever seems loose. Is there a way I can tighten things up and have more reliable shifting?
that's a very common problem on these old trucks - for starters, open up the shift box on the column where you jack around the linkage, clean and re-grease it and see that the spring in there isn't broken - make sure the connections of the rods to the levers on the box aren't sloppy, might need to replace the bushings there [and at the trans] - check your shop manual for adjustment of the shifter up top
Thanks,Bill. I had replaced bushings on levers but not underneath at the transmission - couldn't figure out where they went so didn't mess with it. Nor did I check the shifter spring, so I have a good Idea where to start.
Thanks again,
Steve
