| | | Forums66 Topics128,026 Posts1,055,403 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 22 New Guy | | New Guy Joined: Apr 2010 Posts: 22 | Too often my truck will get stuck in 1st gear or won't shift into reverse. If I open the hood and manually pull the linkage to a different position it works for a while but I need a more permanent fix. My shift lever seems loose. Is there a way I can tighten things up and have more reliable shifting? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | that's a very common problem on these old trucks - for starters, open up the shift box on the column where you jack around the linkage, clean and re-grease it and see that the spring in there isn't broken - make sure the connections of the rods to the levers on the box aren't sloppy, might need to replace the bushings there [and at the trans] - check your shop manual for adjustment of the shifter up top Bill | | | | | Joined: Apr 2010 Posts: 22 New Guy | | New Guy Joined: Apr 2010 Posts: 22 | Thanks,Bill. I had replaced bushings on levers but not underneath at the transmission - couldn't figure out where they went so didn't mess with it. Nor did I check the shifter spring, so I have a good Idea where to start.
Thanks again, Steve | | |
