2 members (DadsFirstPickup, Wally / Montana), 83 guests, and 0 robots.
Topics128,050
Posts1,055,757
#609360 01/12/2010 6:04 AM
hello everyone.
just wondering if anyone thinks this is in anyway possible to put together. I know that it would require extensive frame and sheet metal work, but was just wondering whether anyone knows if it could/has been done.
[IMG]http://i834.photobucket.com/albums/zz265/pcmodder530/customquadcab53.jpg[/IMG]
Thx for your input smile
"MONGO"
"MONGO"
Yup been done. Here's Pics of one from around Kansas City.
Mongo
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
thanks thats perfect smile
quick question. thats a 1 ton and I was wondering whether it would be harder to do a 1/2 ton because of the different frame rails?
I like the idea,the main trick is getting the rear doors,and proportions to look right.
I've seen ones done just using another pair of doors with the forward slant left as is(wierd), but the one Mongo posted must've used door tops from yet another pair to achieve the squared off look.
Either way,it's a lot of work!
More pix on Flickr.
I've seen it done as well.One in particular had the rear doors suicided..I love the drawing ,that would be a hit in my book.......dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
alright thanks guys smile im going to go take a look at the old truck my neighbor has and see if i can possibly salvage anything off of it.
I know its gonna be a lot of work to make it look right but i think it will be worth it in the end.
Y
Y Offline
Just a suggestion, what if you used the front sheet metal from a "Big Bolt"? The front wheels/tires would fit the 1 ton chassis better and if necessary "radius" the rear fenders? I like the idea and have the components, but would consider the 83 1/2 ton frame I have. I'm trying to figure out how to hang the rear doors in the conventional way. The center pillar would have to allow for hinge pockets, and maybe modify the doors too make it look right.
Seems like I saw one at the Sacramento Autorama a couple of years ago....I don't recall any other details. I may also have a pic of it somewhere...
Any other info on a project like this? I have a 5-window I want to do something unique with.
KC Mongo- can you post those pics again? Link not working now. Thanks.
use a 3/4 ton frame the rails are straight after the cab and easier the lengthen or shorten then a 1/2
1949 SUBURBAN
