| | | Forums66 Topics128,051 Posts1,055,729 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 5 New Guy | | New Guy Joined: Mar 2010 Posts: 5 | ... Last year I did some painting. I put on what I thought was enough paint, sprayed the clearcoat and buffed it out with liquid ice. The primer in some areas show. What prep work do I need to do to continue with the painting. I want to put on a few more coats and shoot more clear. Thanks in advance. It is urathane. Thanks...
WG69 | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | liquid ice?? would that be water? ... or the energy drink .... or the machine tool lubricant? I'd say if you don't have enough color under the clear coat, the clear coat needs to come off
Bill | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | I have made that mistake (along with every other possible painting issue). I am no expert but the painting "demonstrator" that work out of the PPG shop said for solid colors you could sand the clear with 800-1000 and shoot more base and then reclear. He said with metallics the clear should be removed. I am using a solid color and that system worked great for me.
Chuck | | | | | Joined: Mar 2010 Posts: 5 New Guy | | New Guy Joined: Mar 2010 Posts: 5 | Thanks Bill and Chuck. Off comes the clear coat. I wonder if I buffed most of it off anyway. A sanding we will go.
Wally | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | If you have primer showing you've buffed through the clear coat and color coat. I'm no paint pro but if were going to buff I'd certainly wet sand with 800 grit to knock off any irregularities first. | | |
