5 members (TUTS 59, MickeyP, Oswald, Gdads51, 1 invisible), 88 guests, and 0 robots.
Topics128,049
Posts1,055,695
#747903 05/18/2011 2:52 AM
I've been rebuilding my 55 2nd series from ground up and finally have it to a point where I can start, shift and hopefully drive down the street however no clutch! There is little resistance in the clutch pedal and when I slowly try and shift into gear when the engine is running, the clutch is not disengating the transmission so lots of grind. I've put a new clutch setup in the truck but it is original style 3 speed manual. New everything on the truck. I can see the fork move in/out and separate the pressure plates when I depress the pedal but I'm surprised at the lack of resistance. Would appreciate any feedback.
It's a work in progress! Started August 08. gotta finish before the baby comes August 20th!
https://picasaweb.google.com/tomnmindy/Truck?authkey=Gv1sRgCOj0gsiF6ZCDKQ&feat=directlink
...the first question is always "is the clutch in with the correct side toward the flywheel?
when I had my 55 Chevy I would stick it in second then down to first never had a problem
1938 Gmc 1/2 ton
It sounds like the clutch disc is stuck to the flywheel or the pressure plate. To free up try to start in gear with the clutch pedal pushed in. SAFTY NOTE: 1, Have working brakes, 2, the truck WILL lurch forward or back depending on what gear selected so make sure you have lots of space in the front and back of the truck. Another method is to put the rear axel on Good jack stands with tires clear of the ground,start in gear, push the clutch pedal in, and hold it in, and apply the brakes.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
hippy #748167 05/19/2011 3:24 AM
.... a new clutch kit should not be sticking this soon??
Whats the latest 55chevytxnguy?
Verify the throwout bearing is on properly if you are using a stamped fork. the clips should be against the inside of the rear flange not with the thin flange sandwitched between the fork and the clips...
did you adjust it properly?
Ok, great feedback. I dropped the tranmission and clutch to start over. pressure plate is facing right direction (it will only install in one direction) but good to check. Made sure clutch fork is on the throwout bearing correctly, reinstalled everything and toqued it up correctly. I even adjusted the rod all the way out to give the clutch the maximum amount of movement. However, I'm having the same problem. This is the correct clutch assembly (got it from LMC Truck). I'm scratching my head. Wasted 2 hours doing all this yesterday.
I will try Hippy's feedback this morning and see if that free's it up.
Longbead, just to double check, would you have a picture of what you are describing on the throwout bearing? I believe I have it correct.
Thank you all. Keep your fingers crossed.
You say the pressure plate is installed correctly. What about the disc? That is the part that can be installed a right and wrong way. If you have the hub towards the engine, it won't work.
Figured out the clutch was simply not adjusted correctly. Too much pre-load. Working like a champ now. Took her out on the maiden voyage this morning! Thanks everyone for your feedback!
See video below
https://picasaweb.google.com/lh/photo/LtrDo3RVpJRkg7T_Vml8nZ_2yPa3jnbmLE9W1FOhrDI?feat=directlink
https://picasaweb.google.com/lh/photo/u7Uc_ZbtU_VQIDyGnxqWAJ_2yPa3jnbmLE9W1FOhrDI?feat=directlink
https://picasaweb.google.com/lh/photo/Bd5aDEBmkLLcyJEzGcZFvJ_2yPa3jnbmLE9W1FOhrDI?feat=directlink
