| | | Forums66 Topics128,134 Posts1,056,401 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | How many cross sills are there under the wood of my bed?
I am thinking there is the front one and the one over the gas tank but am unsure if there is another.
TIA
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Oct 2007 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 63 | see link at bottom regarding youtube video on bed assembly in there is string of photos one showing the bed sills in a 50 which I think would be the same. 4 in total. With mine I found the second sill in front of the rear axle was not fixed down? made my own tapered mounts all good
| | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | You should have one also behind the axle about 23 inches forward from the rear end of your boards. That one needs to have a bed to frame bolt go through it into the frame.
Mar-Ktech | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | So. There are three in front of the rear axle and one between the axle and rear sil?
Thanks again
