Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Shade Baby), 21 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#747263 05/15/2011 9:27 PM
I've got my 235 all tuned up and it runs and idles well however, once the choke (Rochester BC) has opened up, if I turn the truck off, It won't start until the engine cools down and the choke closes. I have the carb adjusted to factory settings but won't start when hot. If I choke it down, just to start it, it works fine.
Am I missing something?
Lode51 #747331 05/16/2011 12:11 AM
Have you tried to push the gas pedal down a few times than try and start ,when the carb is hot the gas inside perks out so if you give it a couple of shots from the accelerator pump that gives the engine some fuel to start.It worked for me when I was running a "B" carb on my 235 and 216.
Pete
Pete52 #747408 05/16/2011 3:24 AM
Riding in the Passing Lane
Your accel. pump may not be working good. Look down the throat of the carb with the engine off & work the throttle. You should see a squirt of gas go in each time you open it from closed possition.
1972 Chevy c10 Cheyenne Super
