3 members (tesa, Bill Hanlon, Gray_Ghost), 76 guests, and 0 robots.
Topics128,076
Posts1,055,925
Members48,430
#74623 03/10/2007 11:37 PM
once again I come begging for help. have finally got my 235 torn down to the point of "trying" to remove the cam. pulled the timing cover off but am clueless as to the next step. head has been removed. also the lifters, pushrods etc.Does the cam slide out now or is there some hidden fastener that keeps it place? once again thanks in advance
ole b97
#74624 03/10/2007 11:55 PM
Riding in the Passing Lane
There are 2 screws behind the gear. Turn the engine till they line up in the access holes. Dont forget the fuel pump & dist. They must come out also.
1972 Chevy c10 Cheyenne Super
#74625 03/11/2007 12:12 AM
oleb97,
There was a thread on camshaft removal a week or so ago. The outcome of the post was that the crankshaft throws can interfere with cam removal. I don't know this for a fact, but it might be something to be aware of. The remedy would be to rotate the crank to a neutral position.
Stuart
#74626 03/11/2007 4:13 AM
I believe that you should line the two timing marks up on the gears and this is the best position, if I remember correctly. Be careful to support the cam as you slide it out or you can hit a cam bearing.
1951 1 Ton Completed
