| | | Forums66 Topics128,268 Posts1,058,391 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 29 | I'm installing a B&M trans cooler with a fan on my 57. Need some mounting location ideas. The normal areas in front of and behind the radiator are taken up with a pusher fan/shroud and overflow bottle.
Looking for ideas on where else to mount. Under bed? Under floor? How?
Hi-Tek Automatic Transmission Cooling System 13-1/2"x9"x3-1/2" with 9-1/2" diameter fan and it will not run to the radiator.
thanks in advance...
| | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | Some suggestions: (1) Mount it inside a frame rail away from the exhaust,(2)mount it under the bed, but away from the driveshaft area,(3) mount it under the cab floor on the passenger side. As to how to mount it: you will have to fabricate some brackets that are designed for the area you choose. | | | | | Joined: Feb 2000 Posts: 5,266 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,266 | I mounted mine back under the bed with plenty of space above and below it. It doesn't have a fan on it and after 11 years the fluid still looks and smells like the day I put it in. I am running a Turbo 350 with shift kit in a 3200 lb truck, I have pulled trailers and drag raced it. As long as it gets air flow, you can put it any where. The low to the ground street rods just tuck them into the frame rails with out problems. Some of the first Power glides were air cooled, they just cut holes in the bell-housing and had some sort of fins on the converter, and they lasted for ever!
Joe | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I'm running a B&M cooler w/fan in one of my trucks and have it mounted under the bed. Geographically, I saw no need to run through the radiator to pre-heat the ATF. However, it might be something you would want to consider as Pensacola gets mighty cold in the winter.
The fan/cooler doesn't require a whole lot of space for air passage and I just used some flat band stock and rubber cushions to secure the assembly. I may have some pics in my Webshots F100 album.
Dave | | |
