2 members (Bill Hanlon, Rich'sToys), 82 guests, and 2 robots.
Topics128,127
Posts1,056,678
Members48,452
#744600 05/04/2011 12:56 PM
I'm trying to replace the cowl vent gasket on my 1941 truck, but I don't actually know how it is supposed to fit the truck, Lip up, groove up??? I assumed I would go to the truck and it would be obvious, but it isn't. I got the gasket from Carter's but it has the Steele rubber logo on it. I'm not sure if it is just ANOTHER ill fitting chinese piece of junk or what, but either way I try to install it, it really doesn't fit well. Any suggestions would be great, and pictures are even better.
Thank you guys, Rob
I think you want " lip up " to keep water away from opening. The gasket I got from Carters doesn't fit very well either / seems too thick / keeps cowl vent above surrounding metal ?
1940 Chevy KC 1/2-Ton
if it says steel on it, then you got a steal of a deal and its the real deal. lip up, the groove fits in the channel. you must remove the vent to get it to go in plus remove all the crap that been in there for 50+ years. at least on my trucks i had to. while your at it look under the dash where the seal goes and look for rust runs and address that too.
If it's at all like my '48, once you force the vent door down, it'll squash the rubber enough to be level, especially as time goes on.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Thanks for the help guys, I'll give it another try this weekend.
I had to use some spray on adhesive of some sort to get it to stay in place. Then squash the vent down to keep it there, aligned. All it wants to do is pop out otherwise.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
I have a 48 and will assume these gaskets are close enough to ask my question.
There are two types of gaskets available. The sponge (which is inexpensive) and another which is twice the cost. Which one is the one to use on the top and side vents?
Thanks and sorry - I am not trying to highjack this thread.
Dennis
Leo Offline
Moderator
Moderator
FWIW, I don't have a 41 but a 53. I have the rubber one, not sponge and I used the weatherstrip adhesive on it. Then I closed the cowl vent overnight and it's there to stay.
Hey 641Workmaster, its nice to see another art deco here in shoreline CT, I'm over in Guilford, I hope to see you on the road one of these days!
